[QUESTION] Sieges de 206 RC dans 306 XS HDI
pom'pote
MessagePosté le: 13 02 2008 15:07    Sujet du message: R&eacutepondre en citant
replaced by something that is a red glow, a piece
of wood or iron, for example
MessagePosté le: 13 02 2008 15:29    Sujet du message: R&eacutepondre en citant
it's ok
valve
MessagePosté le: 13 02 2008 15:56    Sujet du message: R&eacutepondre en citant
Thanks to everybody!!!
I promise i will make a step-by-step manual with photos and very well explained
La decadencia esta prohibida en mi mente
KaRn1
MessagePosté le: 13 02 2008 20:21    Sujet du message: R&eacutepondre en citant
In french I hope
306 DTurbo 1997 - 151000km@230000km [VENDUE]
207 1.6 HDi 110 Griffe 78000km@85000km [VENDUE]
Smart ForTwo Sunrise 0.7T 45cv - 48000km
306 S16 BV6 phase 1 1997 - 97000km ...
valve
MessagePosté le: 13 02 2008 20:35    Sujet du message: R&eacutepondre en citant
How much cost the sparco rally rails? in madrid it costs 63€ each one. is it too expensive?
MessagePosté le: 13 02 2008 21:00    Sujet du message: R&eacutepondre en citant
apparently, 59€ each gere
TOM7
MessagePosté le: 27 03 2008 23:24    Sujet du message: R&eacutepondre en citant
on the second photo you can see an orange piece under the seat, here, this piece is used to keep the seat in place (the wedge="calle" mentionned before).
the goal is to replace this piece by something wich allow you to have a rigid fixaton on the frame (the floor of your car).
if your 306 have 5 doors, you don't have to add the wedge
concerning the rear seat, i can't help you
TOM7
MessagePosté le: 27 03 2008 23:26    Sujet du message: R&eacutepondre en citant
ooops j'avais zapper la derniere page avec les réponse en anglais (s'il vous plait, ca rigole pas ici)
valve
MessagePosté le: 05 11 2008 20:19    Sujet du message: R&eacutepondre en citant
I have mounted the front seats, and the vert part of the rear. but i have no idea to mount the lower part of the rear seat!!
Anyone have some photos to give me a clue?
Thank you for all
socrouss
MessagePosté le: 06 11 2008 12:52    Sujet du message: R&eacutepondre en citant
Give this question at Nicopug...He has some pictures
Mik
MessagePosté le: 07 11 2008 12:05    Sujet du message: R&eacutepondre en citant
Donc, apparemment, c'est possible sans trop de complication finalement... Et c'est quoi cette histoire de hauteur ? Parce que de toutes façons, ces sièges montent déjà très haut dans une RC, et la tête passe sans problème. Ca change quelque chose dans une 306 ? Ah si, dernière question, justement au niveau de la hauteur, le siège est il toujours réglable en hauteur ?
Mik.
306 S16 Premium 2.0L 16v BVM6, noir onyx, phase 2.2, en rodage... Tout est neuf suite resto complète !
socrouss
MessagePosté le: 07 11 2008 12:11    Sujet du message: R&eacutepondre en citant
j'y connais rien dans les RC mais si t'as pas le mecanisme de hauteur remis dessous a mon avis c'est mort
MessagePosté le: 07 11 2008 12:13    Sujet du message: R&eacutepondre en citant
Non Ninja
Oui Ninja
socrouss
MessagePosté le: 07 11 2008 12:17    Sujet du message: R&eacutepondre en citant
le mécanisme de hauteur est pris dans le siège de RC ou tu dois l'adapter de la 306?
MessagePosté le: 07 11 2008 12:18    Sujet du message: R&eacutepondre en citant
Repris de celui de la RC
socrouss
MessagePosté le: 07 11 2008 12:25    Sujet du message: R&eacutepondre en citant
ah ok...
Mik
MessagePosté le: 07 11 2008 12:41    Sujet du message: R&eacutepondre en citant
Alavach' !!! C'est trop classe !!!
J'adooooooore !!! Alors donc, si je récapitule en français ( ), la banquette AR vient en lieu et place de l'origine, et il n'y a que 2 points de fixation à créer sur l'extérieur de chaque siège AV en fait ? Et voilà une 306 RC... C'est bien cela ?
Mik.
MessagePosté le: 07 11 2008 12:59    Sujet du message: R&eacutepondre en citant
il faut des rails de sièges baquets de rallye pour l'avant
Mik
MessagePosté le: 07 11 2008 17:50    Sujet du message: R&eacutepondre en citant
Coulissants ???
Et dans cette config là, ça vient sans faire d'autres points de fixation ?
Mik.
MessagePosté le: 07 11 2008 17:57    Sujet du message: R&eacutepondre en citant
pas les rails coulissant, juste les platines de base
Page 2 sur 3
