Alimentation moteur
MOTEUR INJECTION XU7JP4
BOUCHON DE REMPLISSAGE CARBURANT BOUCHON CARBURANT SANS VERROU
DÉTECTEUR D’EAU FILTRE À GAZOLE SANS DETECTEUR EAU FILTRE GASOIL
CARTER CYLINDRE (MATIÈRE) CARTER CYLINDRE ALUMINIUM
CARBURANT ESSENCE SANS PLOMB
DÉPOLLUTION (MOTEUR) DEPOL CEE 95 (MOTEUR)
PRÉFILTRE MONTAGE SANS PREFILTRE
MOTEUR (TYPE) MOTEUR TYPE XU/XUD
CATALYSEUR CATALYSEUR 3 COMPOSES
REFROIDISSEMENT D’HUILE SANS ECHANGEUR EAU/HUILE
BUSE TEMPÉRATURE MOTEUR BOITIER PRISE T° EAU MOTEUR
RÉCHAUFFAGE CIRCUIT GAZ CARTER SANS RECHAUFFAGE CIRCUIT GAZ CARTER
COUPURE ALIMENTATION CARBURANT AVEC COUPURE ALIMENTATION CARBURANT
VARIATION PUISSANCE (MOTEUR) PUISSANCE STANDARD
RÉGLEMENTATION 70 / 221 (FUITES CARBURANT) AVEC CLAPET ANTI-RETOURNEMENT
RHÉOSTAT AVEC RHEOSTAT
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE L3
VENTILATEUR 1 VENTILATEUR 2 VITESSES 120W
RÉCUPÉRATION DES VAPEURS D’ESSENCE RECUP VAPEUR ESSENCE PILOTE
VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION SAGEM
Boîte de vitesses Transmission
TRANSMISSION BVM5
BOITE DE VITESSES (CARACTÉRISTIQUES) BE3 V
COUPLE RAPPORT CP 19 X 75
COUPLE TACHYMÈTRE CT 22 X 19
STYLE ROUE ROUE OPTIMISEE NOIRE
EMBRAYAGE EMBRAYAGE CABLE CDE ASSISTEE
CHAMBRE À AIR SANS CHAMBRE A AIR
VERROUILLAGE SÉCURITÉ BOITE DE VITESSES SANS VERROUILLAGE SECURITE BV
DIFFÉRENTIEL (BOITE) DIFFERENTIEL STANDARD
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 185X65X14 H
ROUES MONTÉES ROUE 5 POUCES 1/2
ROUE (TYPE) MONTAGE ROUE TOLE
BOITE DE VITESSES TYPE BVM BE3R
Suspension Direction Freinage
ANTIBLOCAGE ANTI-BLOCAGE ROUE
BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR DIAM 19
ANTIVOL ANTIVOL STANDARD
DIRECTION DIRECTION ASSISTEE VARIABLE
ANTIDÉVERS AVANT AV DIAM 18
ANTIPATINAGE SANS ANTIPATINAGE
FREIN PRINCIPAL REPARTITION ELECTRONIQUE FREINAGE
FREIN TYPE DISQUES AV VENTILES/DISQUES AR
SUSPENSION SUSPENSION NORMALE
VARIANTE ASSOCIÉE FREIN ABS5 ADDITIONNEL BOSCH
Carrosserie Equipements
ATTACHE-REMORQUE SANS ATTACHE REMORQUE
AVERTISSEURS AVERTISSEUR STANDARD
ANTENNE ANTENNE PAVILLON COURTE
BRAS RACLETTE BALAI AV SANS DEFLECTEUR
CAPOTE SANS CAPOTE
DÉFLECTEUR AÉRODYNAMIQUE ARRIÈRE MONTAGE SANS DEFLECTEUR AR
ENJOLIVEMENT LATÉRAL (DIMENSION) PROTECTEURS LATERAUX LARG=40 + BAS DE MARCHE
ENJOLIVEUR ROUE (STYLE) STYLE SONATE 6 AJOURS 14 POUCES
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
HARD-TOP SANS HARD TOP
ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT AVEC ENJOLIVEUR SORTIE ECHAPPEMENT INTEGRE
INSONORISATION COTÉ MOTEUR SANS INSONORISATION
ESSUIE-VITRE AVANT ESSUIE-VITRE AV AVEC CAPTEUR DE PLUIE
ESSUIE-VITRE ARRIÈRE ESSUIE-VITRE AR
ESSUIE-PROJECTEUR SANS ESSUIE-PROJECTEUR
OBTURATEUR FACE AVANT GRILLE P/C NON OBTUREE
PARE-CHOCS P/C SPORT AV/AR COULEUR CAISSE DEPUIS MOD2000
PORTE-BAGAGES MONTAGE SANS PORTE BAGAGES
PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD
PROJECTEUR SPÉCIAL (DOUBLE-OPTIQUE) PROJECTEUR DOUBLE PARABOLE
RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETRO EXT CONDUCTEUR CHAUFFANT CDE ELECTRIQUE
RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETRO EXT PASSAGER CHAUFFANT CDE ELECTRIQUE
ROUE DE SECOURS ROUE TOLE + PNEU STANDARD
ACCESSOIRES EXTÉRIEURS POIGNEES EXT + RETRO EXT COUL CAISSE
SUPPORT ROUE DE SECOURS SUPPORT ROUE SECOURS STANDARD
LAVE-VITRE ARRIÈRE LAVE VITRE ARRIERE
TOIT OUVRANT TOIT FIXE
COULEUR CAPOTE SANS CAPOTE
ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS COULEUR CAISSE
VITRE ARRIÈRE (GENRE) VITRE AR CHAUFFANTE
VITRE (ASPECT) TEINTEE
VITRE CUSTODE (NATURE) SANS VITRE CUSTODE
