Je vais acheter dans les prochains jours un nouvel autoradio, et mon choix s'est porté sur cet autoradio:
CDE-9850Ri
LECTEUR CD/MP3/WMA
Tuner
* RDS
* Preset Stations (FM: 18/MW:6/LW:6)
* Auto Memory
* Local/DX Selection
* Up/Down Seek
CD Player
* Regulated 1-Bit DAC
* Zero data Mute (0 Bit Mute)
* Digital Servo
* Music Sensor Up/Dn
* Disc Play/Pause
* Forward/Backward
* Music Search Function
* CD Text, CD Text Display, CD Text Scroll
* MP3 Text Information Display (ID3 Tag)
* MP3/WMA Decoder/Playback
* M.I.X. One (Folder)/All (Random Play)
* QuickSearch Function (MP3 Files)
* CD-R/CD-RW Compatibility
BassEngine®
* Subwoofer Level Adjustment
* Bass Center Frequency Control
* Bass Width Adjustment
* Bass Level Adjustment
* Treble Center Frequency Control
* Treble Level Adjustment
General
* 50W x 4 High Power Amplifier (Micro Dynamics™)
* Drop Down Face
* Full Speed Control
* Rotary Encoder Volume Control (Pop-up Rotary Knob)
* Silver Face w/Blue/Red illumination Buttons
* 1 PreOut (2V PreOut)
* BassEngine®
* Subwoofer Level Control
* Bass Band Width Adjustment
* Steering Wheel Remote Ready
* Media Playback
* Separate Bass & Treble Control
* Fader & Balance Controls
* Loudness
* S.T.M. (Source Tone Memory)
* Detachable Trim Plate
* Anti-Theft Detachable Front Panel
* Dimmer-on Input
* Power Antenna Lead
* Remote-on Lead
* Audio Interrupt In
* Wireless Remote Control Ready
* Demo Function
* Audio Mute
Sinon j'hésite aussi avec celui la:
CDA-9854R
LECTEUR CD/MP3/WMA
Tuner
* RDS
* Auto Memory
* Up/Down Seek
CD Player
* Digital Servo
* Disc Play/Pause
* Forward/Backward
CD Changer Control
* Repeat (One/Disc)
* Music Sensor Up/Down
* Forward/Backward
* Disc Play/Pause
* Elapse Time Display
* CD Text Display/Scroll
* Multi-CD Changer Control (with KCA-410C)
* MP3 Changer Ready (CHA-S634)
* M.I.X. One/All (Random Play One or All)
BassEngine®
General
* Adaptive Steering Wheel Remote Ready
* Black Face w/Blue/Green/Amber/Red illumination Buttons
* CD Changer Control Function
* Drop Down Face
* Quad Illumination
* 3 PreOut (2V PreOut)
* Made for iPod®
* BassEngine®
* Versatile Link™ Ready
* Vehicle Display Interface
* MM Driver Ready (Hard Disc Drive Ready)
* Media Playback
* Loudness
* Dimmer-on Input
* Remote-on Lead
* Demo Function
* Audio Mute
Sachant que je suis pas un super pro en audiocar, j'ai besoin juste d'un truc performant et qui soit fiable.
Lequel me conseillez vous??  |
euuuuuuuuuuh, elles sont où les différences à part le nom du poste
sinon un bon Tokay ou Takara
aucun des 2 ne doit être mauvais mais à savoir lequel est bon
place aux spécialistes  |
Ils ont l'air sensiblement identiques, une préférence pour le 2ème qui permet de brancher son Ipod
(Décidemment tout le monde achète des sources Alpine en ce moment ) |
| sauf mauvaise lecture il y a pas de deca tempo sur les 2 version me semble t il domage si on veut rentre dans des reglages un peu plus possee |
moi deja en alpine je dis aucun souci, moi pour avoir 1 super source j'avais prit le cda 9855r, decalage temporel, filtre integre, et surtout possibilite de faire reglage deouis pc et ensuite les transferer sur le poste, (ipersonoliz) la fonction, si ils ont ces 3 choses l'un ou l'autre seront parfait
si te un pro du caraudio choisit le 2e car il a 3 sorti preampli, alors que le premier n'en n'a qu'une
ben comme l'a bien dit 306Squale, meme avec 3 sorties préampli, le soucis si on veut rentrer dans des réglages plus pointus, c'est qu'il n'y a pas de réglage de correction temporelle donc pour jouer sur la scène sonore, bof bof...
Maintenant, ça reste 2 bonnes sources. Faut voir l'utilisation qu'il en aura le ptit canard
Perso, j'ai un 9853, avec donc la correction temporelle (T.Corr) et aprés y avoir touché avec le squale ce week end, je vous avoue que c'est bien utile pour régler la scène musicale dans l'habitacle...  |
| ykaran a écrit: |
entierement d'accord avec cette phrase !!
je suis pas sur qu'il soit craqué comme nous...
a mon avis, il veut un truc simple, efficasse avec un bon son sans se prendre la tête !!
le déclage tempo, c'est bien, mais ce n'est pas indispensable, c'est un composant final, la cerise sur le gateau d'un install complexe, mais le son n'en est pas meilleur, il est juste plus précis.
Donc mon canard, si tu veux un Ipod prends le 9854, si t'en veut pas, prends le 9850, et pareil pour un install avec plusieurs ampli, si oui : 9854, sinon : 9850.
Le son n'est pas mieux sur le 9854, la partie audio est la même, c'est juste qu'il a plus d'option...
Mais si tous ces équipement ne te serviront pas : prends le 9850 !!  |
Faudrait que je pense à changer le miens aussi, il commence à se faire vieux
J'arrive pas à trouver combien de sortie RCA ils ont? et sinon ils font combien? |
J'ai pris le 9850Ri
Merci pour tout vos avis, je suis pas a fond niveau son comme vous tous, je garde juste une ptite install correcte, histoire d'avoir un joli son bien propre et surtout pour la qualité du matériel.
Le 9850 m'a couté 180€
L'IPOD je n'en ai pas donc je n'en aurai pas l'utilité (enfin du moins pour l'instant)  |
| olive34 a écrit: |
Pas mal, tu as trouvé ca ou ? |
| dr gang a écrit: | | olive34 a écrit: |
+1
Ca m'interresse aussi à ce prix
Une ch'tite question, faut rajouter quoi pour pouvoir brancher la commande au volant? |
Ben au pas de la case bien sur
Pour pouvoir utiliser la commande au volant il faut acheter une interface que l'on peut trouver chez Peugeot ou dans les centres auto  |
pour la commande au volant je viens de regarder ma facture (norauto) :
- interface pour kce870B réf: kce870B 48€
- cable pour psa kwe890e réf: kwe890E 12€ |
| E-Max a écrit: | Faut que j'y aille acheter des fonds noirs  |
Edit Dr gang
| olive34 a écrit: | Ben au pas de la case bien sur
| dr gang a écrit: | | le déclage tempo, c'est bien, mais ce n'est pas indispensable, c'est un composant final, la cerise sur le gateau d'un install complexe, mais le son n'en est pas meilleur, il est juste plus précis. |
Et oui je suis d'accord
Par contre les 3 sorties préamp sont une bonne valeur, on arrive assez rapidement à les exploiter.
Autrement le son entre les deux modèles est probablement exactement le même, Alpine ne va pas s'amuser à réinventer la roue à chaque modèle: ils réutilisent les mêmes préamplis et amplis dès que c'est possible. Donc même gamme et même année --> probablement mêmes composants.
Enfin de toute façon le choix est fait  |
| Crazy306 a écrit: | | olive34 a écrit: | Ben au pas de la case bien sur
En Andorre si tu veux c'est pareil
Je l'ai monté et testé et je peux vous dire que ca arrache bien, meme avec une sono d'origine je trouve que le son est super net et propre
Ca me change de mon vieux sony  |
